Hi guys. I want to make an automation on a clien't site and I need some temperature sensors which I can connect to LAN or WiFi and to get their values in Cerbo/Node-Red. The distance from my Cerbo installation to the sensors is around 100 meters, but I have some building in between so I don't think ruuvi sensors will work and I also cannot use direct wires/cables. I also tried SOnOff sensors, which can be connected to the network, but I can't read their values in Node-Red. Any suggestions ?
