heureka avatar image
heureka asked
Low WS500 field drive controlled by Lynx BMS
All Victron. 800Ah (4 200 Ah smart lithium batts). Lynx BMS system on boat. Wakespeed external control (Lynx) in slave mode. Twin identical Valeo 125A alternators on one engine. Proper dual alt WS500 harness. Target alternator voltage 95C. Latest firmware. No errors / faults.
BMS (set to “alternator mode”) seems to be deregulating alternator field to 30% as shown on cerbo despite battery at 72% charge and alternator temperature steady at 62C. During install testing was experiencing much closer to 100% field as temp rose to target temp. What could be wrong if anything?
system designlynx bms
pwfarnell avatar image
pwfarnell answered ·
Things I would check. These do not relate to the Lynx BMS as I do not know that.
1. When the field is so low what voltage / current is measured vs what you are expecting for absorption / float.
2. Are you using the feature in wire to set float voltage or zero current. Has this got a poor connection as this would reduce field drive.
3. Check what the target voltage / current are in the DVCC settings and see if these are being met and are in line with expectations.
4. Check the battery voltage reported by the batteries, the Lynx BMS and the WS500 sense wires and make sure that there is no mismatch.
5. Check the power and field wire connections on the WS500 and alternators for poor connections.
LED indications, warnings, alarm and error codes
Lynx Smart BMS product page
Lynx Smart BMS online manual
