I am installing 604A of EVE Lithium Batteries on my yacht controlled by the REC BMS. I have separated the Charging and Load Busses so that I can disconnect a HVD or LVD separately and the system can recover. I will use the Ready to Charge signal to turn on/off the separate Victron components ahead of any HVD or LVD event. By separating the Charge and Load Busses however, it means I cannot see how I could use the Multiplus II which would have been my preferred option. I also want to install the Cerbo GX and colour monitor to oversee the system. I have 850w of Solar panels in two arrays which output different voltages (hence 2 Solar Controllers) together with a 120A alternator internally regulated. My questions are:
1. my understanding is the Orion TR Smart 30 has no communications other than Bluetooth and the using the Smart Solar 100/50 with the inverting remote cable means I cannot monitor this via the Cerbo GX (only bluetooth) - is this correct?
2. My inclination is to buy the Phoenix IP45 50A charger (VE Direct) rather than the Phoenix 50A charger (which has a Canbus connection). Does the Phoenix 50A charger have a lithium battery charging profile and which, due to the Canbus communication for this and the Phoenix 3Kva inverter, potentially would be a better option. Any advice on this for a sailing boat?
3. Will the Cerbo GX work with my existing MasterVolt shunt or do I need to replace this?
4. Will the Orion TR Smart DC to DC charge controllers conflict with SmartSolar MPPT controllers if I am running the engine?
5. Will the DC to DC charger be able to extract 60Amps from the alternator if the starter battery is fully charged or do I need an external regulator to achieve full output?
I would appreciate some expert guidance to help steer me on the right track and I am open to other system designs if these would be better.
I have attached my proposed system design (excluding the Cerbo GX and only showing the +VE cabling). Component Design v1.pdf
