stonihiha avatar image
stonihiha asked
contious manually set state of charge by using node red
Hi team,
I use cerbo with smart shunt an incompatible battery management system. The BMS itselve supports modbus. So I can use a different device to connect to cerbo. Now I'm looking for a way to contious manually set state of charge by node red.
I found the >>dbus -y com.victronenergy.settings /Settings/CGwacs/BatteryLife/SocLimit SetValue 80<< command, but no value for state of charge.
Is there a way?
BMSSmartShuntNode-REDSOC
