I have a Victron Quattro 1600 inverter with 2 sunny boys providing solar input into 30kw byd lithium batteries and generator that was 30kva 3 phase converted to 20kva single phase. I am experiencing the Generator amps jumping around between 35 and 45 amps when it is under load and charging the batteries. Initially we thought it was a fuel issue so we have had the tank cleaned, the fuel pump refurbished, new injectors and changed all filters. However we are still experiencing the same issue. I am then concerned that this creates a power surge into the house and could affect appliances. You can hear it if you are running the microwave as the sound of it goes up and down so you know the Generator is hunting slightly. My current thoughts are that the information from the Quattro isn't being acknowledged quick enough by the Generator and the delay is causing the rise and fall in amps. I have also considered EMI filters to help but can't find a suitable option. Any help would be greatly appreciated as the winter months are coming and Generator use will increase now.
