Hi Victron Community,
I have 2x 12v 350w (700w in total) solar panels in series on the roof of my Jayco Swan camper. The Victron Bluetooth app is showing that it’s only producing:
242w / 30.17v / 8amps - under sunny conditions.
@ the battery 2x 100amp AGM’s I have 13.91v and 17.10Amps.
I put the panels in series due to having to use the factory wire which was fitted to the van under construction. My question is does this seem correct??? I am under the impression I should be getting at least double the wattage and amps!
Thanks in advance.
Regards,
Paul
