Hi, I'm running a Victron system since some months now.
Actually a pulse meter is included in the firmware of the cerbo, which is great. In the setup for this device you cut reset the counter to 0, but many times (water etc) you would like to see the actual meter value. So resetting does not do the trick. Is there any chance to "reset" the counter to any value to solve this need?
Secondly is there any possibility to show more fraction of values? As you have normally a ratio 1;10 or 1:100 for m^3, you do not see changes for the first 100 impulses.
Any help appreciated.
Michael
