The spec sheet for the 48/15000/200 Quattro says "Cont. output power at 25C" is 15000VA. I interpret that as the inverter can supply 15000VA continuous, forever. However, Johannes clearly states in this video
https://youtu.be/4SXtGIx0x5w?t=559
That the 15000 rating (in this case) is what the inverter can handle for 30 minutes. So really not continuous at all. That is a huge difference! So if Johannes is right (and he is), what is the max power that I can continuously draw?
Thanks!
Barthold
