I am doing a 800a/hr system on a catamaran using 4 x victron 12v 200ah lithium batteries. I have changed the wiring diagram to be identical to my install. My questions
- Is it ok to connect straight to BMS like this. I have also fused at the 4x positive terminals with MBRF fuses so not to void warranty (I have wired it like this to save cost on 95mm tinned cable, instead of having 8 tails going to a distributor or power in)
- Do I need to fuse each string and then a t type fuse or is one t type enough for victron warranty
- Will the cerbo gx function normally without a multiplus or inverter charger. Also the shunt in the BMS will connect to the cerbo GX and give all nescescary details?
Thanks in advance
