Al avatar image
Al asked
MPPT 75/15 max battery capacity?
Currently I have a MPPT 75/15 connected to a singe 100Ah lithium battery. Does this charge controller has a maximum battery size it can charge? Say for example I add a second 100Ah battery in parallel.
Would it be able to charge that 200Ah total?
charge controller compatibility
luphi avatar image
luphi answered ·
doubling the capacity simply doubles the required charging time, independent from the charger you use as long as the charger fits to battery voltage and battery chemistry
klim8skeptic avatar image
klim8skeptic answered ·
@Al Would it be able to charge that 200Ah total?
Yes it would, given enough sun, panels, and time...
Would it be practical to recharge a 200Ah battery at a max of 15a? Not for regular use, or under less than ideal solar conditions.
Al avatar image
Al answered ·
Cool. Thanks I really appreciate your help.. I just bought a Victron Energy Blue Smart IP22 Charger 12/15. Can that do 200Ah too?
christern avatar image
christern answered ·
To my understanding (and experience) all sources for charging, no matter the power of the charger, gives you charging. It is just a matter of time. In practice you must get enough charging compared to your consumption.
Take solar as an example. A cloudy day, or even several, might give almost nothing during this period. That means you need a bigger battery (bank) if you need continuous supply.
So, your chargers will do fine as long as they can provide what you consume.
