MultiPlus-II (firmware version v506) with the charge profile configured in AGM mode with -18mV temp compensation does not increase absorption voltage to compensate for the battery temperature at 14 degrees. Why?
14.7V + (-0.18V x (14C - 25C)) = 14.7V + (-0.18V x (-11C)) = 14.7V + 1.98V = 16.68V
I am not observing expected 16.7V at all. Instead the MultiPlus-II is hovering around predefined 14.7V without temp compensating.
In which mode temp compensation should be applied: bulk, absorption, float?
