Battery Protect.
Is the 'over voltage' level programmable when used to interrupt charging . I've looked in the manual 'programme table' and it seems that the options are only for under voltage interrupt, though the function is mentioned briefly elsewhere in the manual text? Secondly, if it can be used to interrupt the 'charger' input what then would be the effect if one component of that charge input was an MPPT. In essence what is the impact of disconnection on the MPPT or should the BP be used to 'turn off' the MPPT rather than disconnect it?
