pda1 avatar image
pda1 asked
Raspberry pi- doesn't show MPPT
'Just connected my Rasp 3B+ to my system using Venus os. That part works fine.
The BMV and MPPT are both connected with VE direct USB cables
The BMV-712 is found on Venus
The MPPT 150/60 is NOT found on Venus
I tried changing the cables but there's no difference.
Any ideas how to solve this?
Thanks
Venus OSRaspberry Pi
snoobler avatar image snoobler commented ·
Are they homemade or genuine Victron cables?
Mike Dorsett avatar image Mike Dorsett commented ·
Is the VE direct port on the MPPT set for normal communications? If you use a laptop or other computer with Victron Connect, and the usb cable, does it show up?
pda1 avatar image
pda1 answered ·
The solution- on the MPPT set TX to "normal communication"
That solved the immediate problem.
