osuskio avatar image
osuskio asked
Multiplus II - 10000va Parallel question
Hi
I recently bought 2x Multiplus II 48V/10000VA/140amp (under the advice of a Victron dealer).
So I started my installation last week (11 September 2023 to be exact) Which will be consisting of 2x Multiplus II 48V/10000VA/140amp, Smartsolar 450/200, Lynx, Cerbo GX and Touch GX with 2x Freedom Won 10/8 Lite Home batteries.
So on Monday I was told that its impossible to install the Mutiplus in parralel connection (which the dealer said oh no its very possible don't worry)
So is it possible or will it be better for me to sell both inverters and just buy 15kva Quattro or can it work with the newest Software that was released.
Multiplus-IImultiplus in parallel
The datasheet says no:
It's a HW limitation. I'm not sure if VictronConnect or VE quick configure will prevent you from doing it anyway but it isn't supported and out of warranty.
Your dealer should know that.
