Good day.
I purchased a smart phoenix inverter 12v/3000va which is connected to two lifepo4 12v 200ah batteries, smartshunt and raspberry pi running venus software.
I have not really used any large loads until today where I was running a hotplate which was pulling just over 2000va on the inverter.
After around 10 minutes I had an overheat alarm and shortly after the inverter shut down, on further investigation ive noticed no noise from the inverters built in cooling fan.
Do you think this may be the problem? I seem to remember a cooling fan running on my old 12v 2000va that I had before.
Thank you.
