After upgrading to 3.0/3.1, (venusOS - raspberry pi) my program flow no longer shows VE.bus system control node option to set multiplus switch state in node red as indicated in attached pic. Help screen shows option but it seems to be missing when trying to configure. This used to work; don't know if function was changed (although help shows setting) or if I did something should note, multiplus is currently in ”off” state but would think this should effect node red status or coding - should just show state as “off” but function seemed to have disappeared.
