pps avatar image
pps asked
Combine multiple installations for widget data
Hi, is it possible to draw data from all installations/tags for widget creation?
I currently have a single "Site" of 3 installations. They monitor remote tank levels so it would be nice to have each installation's tank selectable in the one widget.
At the moment I can only fit 2 widgets to a screen, android app.
So potentially a widgets function on the "My Installations" page.
Understand that this maybe just a dream but if you don't ask...
widget vrm
I've been told this:
"This should be doable with nodered, dashboards and the vrm api."
Worth a try.
nickdb avatar image
nickdb answered ·
The easiest way to achieve this is to use an external source to aggregate the data.
I think Victron have a long list of higher priority stuff to dev.
Node red has a vrm api node, you can use this to pull data you need and then create your own nodered dashboard, this is also accessible remotely via VRM.
Its a bit of effort but not too much if you have some integration skills.
pps avatar image
pps answered ·
Thanks
Will investigate Node Red.
