I like installing the wire box covers on all of my MPPT's, it appears better i.e. fit and finish / look and feel.
However, lets say I install a 250/100 MPPT. It can take a wire size of 35mm2 easily. But when I install a wire box (as shown below), the space for the wires only allows me to use a 25mm2 MAX. If I wish to install 35mm2, I have to remove the wire box.
My question is, do you have the same problem and what do you recommend? Do you alter the plastic middle section of the Wire box (as shown below) . Also, the two wires have to share the space with a "holding" screw, so this is probably the root cause of the "reduction in space".
It is the same for the 150/45 (medium) MPPT wire boxes.
