Good evening,
I have read some messages, that DalyBMS is working fine with Victron Products.
However, I found the HiBMS and it looks more or ess the same as the DalyBMS.
Does someone has an experience to share with me?
I have a Customer which need an enormous Energy Storrage for an Off-the-Grid Solution and has access toe "cheap" LiFePO4 Cells. Do be more precise the 310Ah "standard" ones which are sold everywhere.
However, the support from HiBMS sayed, that the maximum number of Batteries/BMS parallel is 8, hence not enough capacity for my customer (16 cells = 51,2V x 310Ah = 15,8kWh x 8 = 127kWh)
Question;
Is it securely possible to Create a Battery with 4p16s hence 1240Ah and 51,2V which then give 63,5kWh and put a 300A BMS with Balancer on it...
...and then use 8 of this sets in parallel to get 500kWh.
If I see the price for the cells (8 cells for a 25,6V System cost already 2100€) on AliExpress I get already gray hair, but my customer has a space problem, which mean, he can not use 72 cells SOPzS 4350Ah to get 626kWh (=500kWh @DOD80). They would have without shelf 17,3t and need three Car Garages minimum, because you can not put Cells with 240kg each in a shelf. Hence you need a big surface accessible with a Forklifttruck or crane. Also the (heated) Betonplate would be something like 30cm thick.
