Devices on network:
1. (3) 240 ah agm batteries in parallel
2. (1) Victron BMV-712 battery monitor
3. (2) Victron 75/15 smart solar controllers
4. (2) solar panels
We connected the panels to the controllers then to the batteries. Both controllers worked and showed up on the network. Then we added the Victron battery monitor. The network shows up, however one of the controllers cannot see the battery.
Ideally, in what order should devices be added in order for all devices to see each other.
