Hi, All.
I would like to ask for your help on the following installation and setup. I have been fighting with the setup for more than 3 days and no outcome. I was helped by our forum colleague (Andrew - Ponzoa) a lot during these days since he is very experienced, but we have not managed to make it work as expected. A big Thank You and my deepest appreciation for your help and I do hope you can continue helping me fix this. :)
Guys,
I have 3 x MP II 10000W/48V, 1 x Fronius Symo 10-0-3 and 8 x Pylon US3000C, 1 x Cerbo GX. They have all been updated to the latest firmware versions, including the Fronius.
Fronius is installed on the MPs output and configured to run in the ESS on the output of the MPs. Fronius country code set to MG50, although it turns back to International 50Hz and I was told by Andrew that it is fine, because it works.
Everything perfect until the Fronius PV inverter starts to produce more solar power. If the production is low (like a few hundreds watts), there is no issue, this is what I noticed.
So, MPs synchronize with the Grid (setup up for Romanian grid code), connection time set to 60s, and Fronius to 120s (reconnect time). After Fronius synchronizes as well and starts the energy production, the MPs disconnects from the mains (grid) and Fronius reboots. And it happens like this in an endless loop. If I disconnect the grid breakers (switch off the breakers on the AC Input of the MPs) and restart the Fronius inverter, everything is just fine. The batteries are being charged and the house loads are supplied (house loads all connected to critical loads output AC1). So, it works correctly as in an off-grid system, but as soon as I connect the grid and the Fronius inverter starts producing power, the MPs get disconnected from the grid. But, I do not get any errors and I do not know the reason for getting disconnected. This behavior gets me crazy and worried at the same time because this is the reason I purchased these MPs.
Do you have any idea of why this happens?
@Guy Stewart (Victron Community Manager) may I ask for your help? Can you help me, please?
I attached a few snapshots from the Remote Console.
Thank you in advance.
All the best.
