Hi!
I have Victron Wallbox EVCS, I bought Tesla Y and I have strange issue while charging.
1) In Manual mode: It starts charging, everything's fine. But when I stop charging (no matter on wallbox or car side) and I start charging again, it's stuck. Wallbox claims "Waiting to charge" and when I try start charging on Tesla, Tesla says that command has been recently sent. If I want to continue charging, I have to unplug and plug in Typ2 connector in car again. Then it starts charging.
2) In Auto mode: Very similar scenario. Charging starts OK (when PV battery is charged and there's feed-in into grid), but when it stops charging (because no sun for the moment), it never starts charging again. I have to unplug and plug in charging connector.
Same Tesla Y car works fine on other wallboxes, I can stop and start charging many times without any issue. Also other car (tested on BMW i3) works fine with Victron EVCS.
I did CP calibration, it didn't help. All firmwares (Victron, Tesla) are up to date.
Does anyone has Victron EVCS and Tesla car? Do you have same behaviour?
