Please check my config and confirm it will work based on Pylontech BMS supplied SoC:
Desire: ignore AC input at 60% and above. If drop below 60%, use AC input for 30 minutes.
The programmable relay says "State of Charge (internal battery monitor)" - implies it has to be the Quattro's battery monitor. Does this need to be enabled in VE Config? If so, will the Pylontech BMS supplied SoC override the Quattro Battery Monitor?
Assistants:
- general flag user
- programmable relay
- relay locker
general flag:
programmable relay:
relay locker:
Thanks!
