xsilvergs avatar image
xsilvergs asked
Relay Node swaps to relay 1
I'm using the Victron "Relay Control" node to control relay 4 on an RPi4
I have noticed a problem were when I make any change any node and then "Deploy" the relay changes back to relay 1.
In this image you can see top left under "Current stored state", "Venus relay 4 state" but below "Measurement" has defaulted to "Venus relay 1 state".
Re-deploying after any changes, changes relay control to relay 1 from 4.
Has anyone else come across this? Is this because I'm using and RPi and not a Victron Venus Device?
Node-RED
nishad avatar image
nishad answered ·
No solution but I can confirm this behavior of the Relay Node
