florian105 avatar image
florian105 asked
EV Charging Station - Waiting for Sun / EV Ladestation - Warten auf Sonne
Hello everyone,
unfortunately my charging station does not work in "AUTO MODE" I only get the message "waiting for Sun"
The battery is full and the connection to the Cerbo is established.
The charging station is only connected via 1 phase.
I hope you have a few more ideas because I can't get any further...
 I am grateful for any help!!!
You can also find videos below. One shows the charging station in "Auto" mode and the other in "Manual" mode when charging.
my setup:
2 Pylontech 4.8KW
1x Multiplus 2 48V 5KW
1x Cerbo GX
1 x EV charging station
Energy meter EM24
PV power is fed into the grid via 1 phase
Hallo zusammen,
leider funktioniert meine Ladestation nicht auf "AUTO MODE" Ich bekomm immer nur die Meldung "waiting for Sun"
Der Akku ist voll und die Verbindung zum Cerbo steht.
Die Ladestation ist nur über 1 Phase angeschlossen.
Ich hoffe ihr habt noch ein paar Ideen den ich komme nicht mehr weiter...
Ich bin über jede Hilfe dankbar!!!
Weiter unten findet ihr auch Videos. Das eine zeigt die Ladestation in "Auto" Mode und das andere im "Manual" mode beim laden.
mein Setup:
2 Pylontech 4,8KW
1x Cerbo GX
1x EV Charging Station
EnergyMeter EM24
PV Leistung wird über 1 Phase in das Netz eingespeist
Video "Waiting for Sun"
Video EV.mp4
Video "switching between "Auto" to "Manual" Mode
Video EV1.mp4
Video Cerbo
Video Cerbo.mp4
ev charging station
video-ev.mp4 (23.4 MiB)
video-ev1.mp4 (76.5 MiB)
video-cerbo.mp4 (28.9 MiB)
Hi, it is not starting because the system does not have a PV system. If there is one, it is not Victron or is not connected to the system. It should look like this: 1691746874039.png
florian105 answered ·
No, unfortunately that is not correct. I have a surplus that is detected by the Em24. From here the Pylontechs are loaded.when these are full, the surplus can also be used to charge the EV station.This is definitely possible!!!
VID_20230811_135445.mp4
Nach einem kopletten Systemneustart ink. Pylontechs rtc hat es funktioniert. Now it works !
Siehe Video und Bild
Lucian Popescu (Victron Energy Staff) avatar image
Lucian Popescu (Victron Energy Staff) answered ·
One of the conditions to start in automatic mode, is enough PV power. If it is not detected by the EVCS, it will not start. Probably, on your video, you have started it in manual mode and then switched it to automatic. You can add a second energy meter, defied as PV inverter, then it should be fine.
