fpsthomas avatar image
fpsthomas asked
Midpoint increase under load
Hey community!
I've searched around a little on my current issue and cant really find a fulfilling answer.
I have two 130ah deepcycle agm's paralel for my 24v system in my camper. It was all out together in quite the hurry because im using it now to go on a work trip. So i must say i didnt charge the two batteries separately before the install because the hurry.. That might be the cause of my question but i cant tell for sure with my experience lacking a bit in these kind of systems.
I have fluctuating voltage when a small load is applied on my 24v system from 1% to 7%. I've disconnected my multiplus and my 3 mppt's 75-15"s to make a clearer view in the Victron connect app on whats going on.
See the attached image. The next one is a bit more zoomed out to see more time on the axis and the repetitive issue with my fridge.
In resume, together with the pictures. Is this only due to for example one battery being in a lower state of charge than the other? And fixable with some battery cycles or seperately charging the batteries to 100% SOC and reconnect the system.
Or is one battery not healthy and needs replacing?
I hope i've included enough info to paint a clear picture
discharge levelleisure batteriesparallele batterien
netrange avatar image
netrange answered ·
Do you use a Balancer for a your serial Batteries ?
fpsthomas answered ·
My suspicion was correct.
I just woke up to and my fridge was defrosting itself. Powering on and shutting off again. Luckily it can also run on 12v, so i disconnected the faculty battery that sinks too low during load & recalibrated the mppt's. Then atleast my fridge works but the multiplus will be disconnected until i have my new 24v battery.
Best regards
