This is an update to a previously asked Question as I have not received any Answers as to why exactly My Cyrix ct is not functioning correctly.
So as far as I can see my Starter Battery reaches all the Voltages it should and Falls again after stopping so I am perplexed as why the Cyrix does,nt open to separate my Batteries. Is it to do with my Lithium Leisure battery ? I need to rectify this problem so does anybody have any advice on what I should replace the Cyrix ct with ? Ideally it would be great if the replacement was very similar in connections and dimensions as it is all set up to fit in the battery box. Thanks for any advice.
