I am close but still not there. Running charge control assistant on Multi. Relay opens wire and charge stops. Works fine manual on Vrm.
"id": "b1eebfa674cf3134",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "3b7a75fd72d55474",
"type": "victron-input-system",
"z": "b1eebfa674cf3134",
"service": "com.victronenergy.system/0",
"path": "/Dc/Battery/Soc",
"serviceObj": {
"name": "Venus system"
"pathObj": {
"type": "float",
"name": "Battery State of Charge (%)"
"name": "",
"onlyChanges": false,
"roundValues": "1",
"x": 190,
"y": 420,
"wires": [
"98cfa7961bbb484e",
"b330a76ea6b10a2b"
"id": "98cfa7961bbb484e",
"type": "debug",
"name": "debug SoC %",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 540,
"y": 340,
"wires": []
"id": "63ee05797f7e9d29",
"type": "debug",
"name": "Charger 1=On 0=Off",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 600,
"y": 700,
"wires": []
"id": "b330a76ea6b10a2b",
"type": "switch",
"name": "% SoC",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "btwn",
"v": "0",
"vt": "num",
"v2": "70",
"v2t": "num"
"t": "btwn",
"v": "80",
"vt": "num",
"v2": "100",
"v2t": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 500,
"y": 440,
"wires": [
"2236aec7beb5f05c"
"34596382e6569acf"
"id": "3c1cdae2c1c58679",
"type": "debug",
"name": "Charger on",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 890,
"y": 340,
"wires": []
"id": "34596382e6569acf",
"type": "change",
"name": "Charger off",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "0",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 710,
"y": 460,
"wires": [
"73520b1bef03227c",
"cb4296f25da09437"
"id": "2236aec7beb5f05c",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "1",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 710,
"y": 400,
"wires": [
"3c1cdae2c1c58679",
"cb4296f25da09437"
"id": "73520b1bef03227c",
"type": "debug",
"name": "Charger Off",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 890,
"y": 520,
"wires": []
"id": "2eb5259d93d5ace6",
"type": "victron-input-relay",
"path": "/Relay/0/State",
"serviceObj": {
"pathObj": {
"type": "enum",
"name": "Venus relay 1 state",
"enum": {
"0": "Open",
"1": "Closed"
"initial": "",
"name": "",
"x": 220,
"y": 700,
"wires": [
"63ee05797f7e9d29"
"id": "cb4296f25da09437",
"type": "victron-output-relay",
"serviceObj": {
"name": "Venus device"
"pathObj": {
"type": "enum",
"enum": {
"0": "Open",
"1": "Closed"
"writable": true,
"disabled": true
"initial": "",
"name": "relay1 0-Open 1-Closed",
"x": 1130,
"y": 420,
"wires": []
