hi this is ESS system with 5kVAnmultiplus II and 250/100 charge controller and BYD lithium battery.
Why multi is converting as much as he can with plenty excess power (battery full and 5kW from solar ) even I select "limit inverter power" to lets say 1kW ?
this limit is only for supplying house loads ? do not work for export ? Multi will be exporting all he can with "feed-in excess solar power"selected ?
