I am trying to setup a multiplus-II with the following requirements:
- Charge battery during off peak night time tariff.
- Batteries should be used to provide power to no break loads.
- If batteries are low then pass through grid to no break loads.
- No feed-in to the grid or to grid side loads from battery.
I wanted to use grid code "none" to meet requirement 4. However, to meet requirement 1 I believe that I need ESS enabled, which needs a grid code. If I set my grid code is there another option in ESS to disable feed-in?
Or could I meet requirement 1 using modbus or MQTT with the grid code set to "none"?
Thanks
