Good Day,
I have a 60KVA victron system installed, and have 6 x SmartSolar MPPT RS 450/200. The 5 units are charging and the 1 unit stopped charging. There is sufficient PV voltage on the charger and it is also reading the battery voltage. The charge power on this device will fluctuate between 8W and 17W at times but is not constant. It looks like it wants to start charging and then switches off then does it after a minute or so again.
I have attached a picture of the victron connect screen of this particular charger. Can anybody please assist.
Thank you very much,
