repairdad avatar image
repairdad asked
How to shutdown MultiPlus 3000 for low battery
I have MultiPlus 3000 24V with AGM batteries, with a battery Shunt and a Color Control GX panel. I'm trying to figure out where to set the inverter to shut down once the state of charge hits 50%.
I had a situation where the inverter stayed active and discharged the batteries to 20%. I'm hoping there is some setting that once the state of charge hits 50% the inverter will stop inverting. I don't want to ruin my batteries.
I have the MK-3 interface in case this setting can't be done though the GX control panel and has to be done directly in the inverter.
Please help .....
Battery Protect
Marc Heymans avatar image
Marc Heymans answered ·
You can connect your Unit to your laptop via the Mk3 cable and use VE configure to set the Dc cut off in the inverter tab
