Hi, currently running an MPii with 4x Pylontech US2000s. Everything is great. I don't use the AC out, it's running as a grid tie ESS. Using solar too on the AC side.
What I want to do is add a second Multiplus with a different type of battery (thinking EVE LiFePo4 cells and Batrium BMS).
If this works then I can scale the system up over time with more MPs.
Is this feasible? or do both the multiplusses need to be connected to the same battery?
