virginio avatar image
virginio asked
S7-1200 ModBus TCP-IP communication problem
Ahoj, taky mám stejný problém s komunikací ModBus TCP-IP s Cerberusem. S klientem jsem četl službu s ID226, zatímco s PLC Siemens S7-1200, ale s chybou služby 255.
jak jsi to vyřešil?
Díky za pomoc...
Hi, I have the same ModBus TCP-IP communication problem with Cerbero. With a Client Software I read the service with ID226 while with the Siemens S7-1200 PLC I have error with service 255.
How did you solve?
Thanks for help...
Modbus TCP
janieronen avatar image
janieronen answered ·
Could you take screenshot from GX-device Modbus error? Like that:
Check and re-check you have same ID than you can see in your GX modbus TCP services list
After all these you can load full error log from device:
screenshot-2023-07-21-at-205115.pnghttps://www.victronenergy.com/live/ccgx:modbustcp_faq#support
