david-emanuel avatar image
david-emanuel asked
Victron SHS 200 MPPT
I have a brand new SHS 200 MPPT v3.0, that is asking for an activation code at startup. I tried entering the Starting Code that is available on the device setup menu and it shows that the code was already used.
As per SHS 200 manual, it says that is also possible to use the SHS 200 without the PAYGo function. The device is simply active forever and does not require any token to be unlocked.
Does anyone knows how to activate this option or how to get the activation code?
MPPT Controllers
chaser avatar image
chaser answered ·
I have exactly the same problem and am wondering if there was a simple solution that I've somehow missed. It's not talked about in detail in any of the manuals that I have some across.
I don't need the PAYGo function at all
