Hello!
I have the following Victron configuration:
I have some problems with the configuration of my Orion DC/DC, I have a Pegeout Boxer model 2022 motorhome with Smart alternator.
The first time I had connected the orion with the wire bridge as Standard and the engine stop detection activated, the problem was that based on the detection threshold set in victron connect that was activated based on the voltage of the engine battery, the problem that the battery with the smart alternatore never or hardly ever reaches 14 volts so the orion hardly charged.
I have connected it as in figure 1 (Engine Shutdown det. override), now the orion always charges until it reaches the charge limit entered in the app with input voltage blocking parameters, which is an unsatisfactory because it continued to charge even with the engine switched off until it reached the set lock value..
it is also written in the instructions "if the ignition switch in figure 4 is switched off, the charger will return to "engine shutdown detection" mode, it will not turn off the charger."
Now if I connect as in figure 2 the bms is no longer connected and cannot disable the charger if needed for example if the temperature is below 5 degrees...
do you have any ideas how to do this?
I want when I turn on the engine the orion charges and when it turns off it also turns off.
Thanks
