CERBO GX cannot change Switch ON / Charger Only from the touchscreen the error message is that with VE BUS BMS is not possible but we changed from VE BUS BMS version 1 (where was not possible) to VEBUS BMS version 2 that Victron advise that is possible
Configuration is;
- CERBO GX (firmware v3.00) connected to VE BS BMS V2 on the "REMOTE PANNEL PORT"
- VE.Bus BMS V2 (firmware v113) connected to a 200AMP 12V Victron Smart Lit. Battery with the 2 cables to the cerbo on the "REMOTE PANNEL PORT" to the Victron Ve.BUS MAINS DETECTOS on the "Quattro port"
- Ve.BUS MAINS DETECTOS connected on 1 side to the BMS and on the other port to the QUATTRO 12/3000/120 2x50 inverter chager
- QUATTRO 12/3000/120 2x50 inverter chager (firmware v505)
- All units included BMS and battery are upgraded to latest sostware versions
- DVCC is enabled an see correctly BMS and control correctly solar chargers
The only problem is that we cannot control Charger Only/ON of the inverter and leaving it swiched on the boat 24 hours drain the battery normally we swich on the inverter only to make a coffie offor hairdrier (the quattro is located in a point where the button in difficoult to access)
Thanks in advance
