I get this message atfer importing The Dynamic ESS .Json
I is not clear which additioanl Palette's are neccessairy to run the flow.
" Flows stopped due to missing node types.
- ui_tab
- ui_group
- ui_template
- ui_text
If looking at the available Palette's the are overlapping templates with UI_ or Dashboard
This is not a Victron problem but a Node-red issue . if installed both they start competing .
Would it be possible to list the required Templates to make the Dynamic ESS flow properly.
Installed templates at the moment
@victronenergy/node-red-contrib-victron
- node-red 3.0.2
- victron-dynamic-ess 1.4.32
