Zoltán Balogh avatar image
Zoltán Balogh asked
Connect AC to the programmable relay of Inverter RS
Hi!
In the manual of the Inverter RS you wrote: "Programmable relay which can be set for general alarm, DC under voltage or genset start/stop function, including minimum closed time and relay-off delay. DC rating: 4A up to 35VDC and 1A up to 70VDC"
Can I connect a 230V AC unit to this NO/NC/COM ports? It's a little relay, it consumes 0.4W
Thanks!
inverter rs
derrick thomas avatar image
derrick thomas answered ·
The manual lists the rating for the relay. If your proposed usage does not fall withing the parameters outlined in the manual do not connect it in that fashion. You can however use the relay to drive an external relay of your choice as long as the external relay driver is within the required specs.
Inverter RS Product page.
Inverter RS Online Manual.
Inverter RS Datasheet.
