micmad avatar image
micmad asked
Victron & Polytech --> Sonnen 2500 LFP2 possible to use without Sonnen System components?
I rescued some Sonnen 2500 LFP2 from disposal.
now i want to use them in my Victron 48V System
but the battery need's spezial comunication to
get and stay alive - Manufacturer is Polytech and ther
Battery's are suportet by Victron - with minor modification
of comunication Sonnen 2500 LFP2 schould work as
well.
can anybody help?
48v battery
matt1309 avatar image matt1309 commented ·
Could you just use a smart shunt rather than having BMS communication, they're pricey but i think otherwise you'll need to write custom driver to get BMS communication to work unless someone else already has.
trpkosj avatar image
trpkosj answered ·
have you found any solution? I have 3 pieces of LFP2 and want to use them with Victron...
Thanks,
Jirka
micmad avatar image
micmad answered ·
Yes - I found that you can use
BatteryView_us2000b_series_3-0-26 to reset communication timeout
so Battery stays alive - with internal protection
To get lifedata from the Battery --> Wifi and MQTT
https://www.rustimation.eu/index.php/solar-pylontech-akku-ueber-konsole-aufwecken/
no wakeup so far with LFP2500 but rest works so far
best regards
MIC
Bouke avatar image Bouke commented ·
Hi, do you mean you updated the firmware on the sonnen lfp2 to the pylontech us2000b firmware?
They now stay on and communicate with victron?
That's amazing if it's that easy. I'm scared to brick my battery's though.
micmad avatar image
micmad answered ·
Nope - no Firmware update,
just connect via RS232 and open BatteryView_us2000b_series_3-0-26
(Country settings in Windows must be American !!!)
select the correct Com Port - start to Scan
then go to Options --> Control Pan
Click in the Set Row on line 3: Close external comunication timeout
cell turns green --> the Battery stay's alive - just switch on or off with green button
or internal Protection
but no communication with Victron Components thats part 2
Sonnen RS232 --> D1 Mini --> WIFI --> mqtt --> NodeRed --> Batt % to Multiplus
good luck
Michael
