I have 2 victron blue solar MPPT 100V50A controllers fed from 2 separate solar panel strings that face in slightly different directions. They are feeding one 12V 600AH sonnenschein A600 solar battery bank.
I would like to know if I can use a cable to synchronise the two controllers as I notice they are sometimes in different phases of charging. ie one can be in bulk or absorb while the other one may be in float.
I do not want bluetooth connection
They are both connected with 10mm2 cables to a common bus bar that is connected to the battery with 50mm2 cables.
Thanks Joe Glennie
