I am planning to install an off grid 3 phase system with 3 Multiplus II 3000VA inverters. Considering the specifications of BYD I need a 16KWH (LVS) battery bank and from Pylontech 14,4 KWH (US2000). This "oversizing" has to do with the peak power rate which is too low at less capacity.
The questions is: Installing Victron Smart Lithium Batteries of 10 KWH will be sufficient (peak power 400A)?
Unfortunately it was not possible to find any documentation that could be a guide for a battery bank sizing with Victron Smart Lithium.
