Is it possible to use the 3.5mm audio jack on the RPi to output audio?
I use the large image and wish to output an audio warning using Node-Red.
If anyone has has a suggestion I'd much appreciate their ideas.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
The audio jack on RPIs is headphone level so you may need a power amplifier to feed a passive speaker, or powered speaker like you'd plug into your computer's sound card.
As far as if Venus OS keeps this output active, I don't know. Worth a try though.
@Kevin Windrem Thanks for reply, I have tried headphones but there was no audio output. I'll give it more thought.
You can to hook a beeper to the output assigned to Venus OS relay 1 and set that to alarm. This won't catch alerts you create in Node-Red but if you have access to another relay output you may be able to access that from Node-Red.
I had considered attaching a piezo sounder to one one of the gpio pins using your RpiSetup for additional relay pins and driving it using Node-Red. I really fancied speech type warnings so we (wife) knows what the warning is for.
Thanks again for your suggestions.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
65 People are following this question.
