I'm using a CT sensor connected to a Multiplus II GX to monitor the meter tails where it comes in from the grid.
My PV array is connected to a Fronius IG TL which then has an ET112 and feeds back into the consumer unit.
For some reason the numbers aren't be calculated correctly.
See above, with the 2470 generation and 1758 charging, I would expect the AC Loads are probably about 700 and the grid about 0.
Any idea where I might have the config wrong or what I could try tweaking to fix this?
Thanks
