Hello
I’m looking to improve my solar yield. Basically I have 2x 450/100 MPPT chargers. Panels are JAM72S20 460:MR.
At present I have 4 strings (3 south, 3 south, 3 east, 6 south) on my roof. See image below.
I’m thinking will I see better yield if I combine the 2x strings (number 1 “blue” and 2 “green”) under 1 string?
The other thing to consider there is 1 panel (panel 4) on the green string which will get shading sooner than the others due to the higher elevation shading from string 1.
This happens as the sun is south west position.
Thank you
