I need help regarding the correct battery settings for LG Chem Resu 13, i found informations only for versions up to 10. The system contains: 1x Quattro 48|10000, 1xlg chem resu13 and 1xmppt
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
The capacity is about the only difference, set that to 252AH (see the datsheet for the battery); use the recommended
settings for the 10.
Just a note though 1 x resu 13 is way too small for a victron 10kVa. Better to use it on a 5kVa. The tech specs for the battery are here.
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
68 People are following this question.
