dcw avatar image
dcw asked
LIFEPO4 Battery Orientation
With regards to the batteries LFP Smart 12.8/200 and LFP Smart 25.6/200
Can they be installed with the longitudinal axis in vertical position ?
Lithium Batterybatterybatterylife
nickdb avatar image
nickdb answered ·
This is covered quite adequately in the manual:
4.2. Physical installation
4.2.1. Mounting
Mounting must meet the following requirements:
  1. The battery must be mounted in an upright position.
  2. The battery is only suitable for indoor use and needs to be located in a dry location.
  3. Batteries are heavy. When moving the battery into its destined location, use suitable handling equipment for transportation.
  4. Ensure adequate and secure mounting as the battery can become a projectile if involved in an accident.
  5. Batteries produce a certain amount of heat when they are charged or discharged. Keep a 20mm space on each side of the battery for ventilation purposes.
Battery Compatibility
