I do not activate VRM on LAN. The wifi is very bad (long distance) and i must put an amplifier to connect the wifi. With the amplifier i had 23% of connectivity. (very bad). I can have a LAN câble, but i can't activate the LAN for VRM. What's happen?
On my lan router I can see my victron
I can acces VRM only by wifi, but i have a lot of network outages..
But if the wifi link if bad, I don't see the complete cutoff of the venus. the router keep already the connexion with the VENUS, but the VRM not. The Venus does not reboot, to pass on the LAN. as explain in the documentation. See the mac adress are not the same on the two links. Why?
