I need to switch on/off a 230V heater depending on the internal cell temperature of my Pylontech batteries. For switching, I want to use a relay of my Multiplus II.
As far as I know, AC OUT2 can be used as well as AUX RELAY.
But my knowledge is that both relays can only be controlled via an Assistant.
But I need controlling within Venus OS on raspberry respectivly Node RED.
The only solution I figured out is to connect
# Relay 1 Pin 40 / GPIO 21
21 out relay_1
to AUX1 INPUT of the Multiplus and set up Assistants to drive the EXT RELAY depending on the AUX1 INPUT state. The, the relay can be controlled e.g. via Venus WebGUI or MQTT.
I haven't try so far. Can anybody confirm that this should work?
But there should be an easier way to controll the Multiplus-relays, especially without the need of an signal-wiring.
Bye, Alex
