So I tried to update a EasyPlus 12/1600 with VE.Flash my old firmware was 1906132 and I tried to updating to 1906209. Now the unit appears to be bricked. It just went to the second step and did not get to the loading firmware. Says to " Please reset the Multi/Quattro/Inverter!. Follow the instructions below: .... (which I did) Press OK AFTER the above steps are done."
Then says can't connect (after it connected before) and says "Try again?"
and in a endless loop.
Unit blinking LED and no amount of restarting gets it to start with old firmware. Can't figure out what to try next. Tough situation as boat in remote Alaska with no dealers anywhere near-bye.
Philip
